How to Configure Battery & App Settings for GPS Performance
Battery & Phone Settings for GPS Accuracy
To ensure accurate GPS tracking, please check your mobile brand and configure the following battery and app settings accordingly:
For Xiaomi, Redmi, Samsung Users:
  1. App Permissions:
    • Go to Phone Settings → Search "Apps" → Open App List/App Management.
    • Find "MAPS" and tap on PermissionsLocation → Select "Allow all the time".
    • Go back one step and select Physical Activity → Set to "Allow".
  2. Google Maps Update:
    • Open Play Store, update Google Maps, then launch the app.
    • Locate your live location and verify tracking accuracy.
For OPPO, OnePlus, Realme Users:
  1. Battery Optimization Settings:
    • Go to Phone SettingsBatteryMore Settings.
    • Turn off "Sleep Standby Optimization".
    • Navigate to App Battery Management → Search for "[Application]" → Enable Allow background activity and Allow auto-launch.
  2. App Permissions:
    • Follow the same steps as above to allow MAPS and Physical Activity permissions.
For Vivo Users:
  1. Battery Usage Settings:
    • Go to Phone SettingsBatteryBackground Battery Power Consumption Ranking / High Background Power Consumption.
    • Find "[Application]" and set it to "Don't Restrict".
  2. App Permissions:
    • Follow the steps to enable MAPS and Physical Activity permissions, then update Google Maps from the Play Store.
For Motorola Users:
    • Go to Phone SettingsBatteryBackground App Use → Tap on Apps.
    • Search for "[Application]" and set it to "Always Allow".
  2. App Permissions:
Final Step:
After configuring these settings, restart your device and check if GPS tracking is working properly.
By following these steps, you can ensure uninterrupted GPS tracking and prevent issues caused by battery optimizations or app restrictions. 🚀
    • How to Use GPS-Based Attendance Tracking in BreezeFSM?
      Overview BreezeFSM supports GPS-based attendance tracking to ensure accurate and location-verified attendance logging for field sales teams. This feature helps businesses monitor workforce presence, prevent false check-ins, and improve ...
    • ✅ Do's And ❌ Don'ts for BreezeFSM Users
      ✅ Do's for BreezeFSM Users ? App Usage & Daily Activity: Login Daily: Always log in at the start of your workday to mark your attendance properly. Sync Data Regularly: Ensure your data (Orders, Collections, Visits) is synced frequently. Make a habit ...
    • MobiLearn App Installation – Google Play Store (Android)
      This document explains the step-by-step process to install and log in to the MobiLearn mobile application from the Google Play Store. Step-by-Step Instructions Step 1: Open Google Play Store Unlock your Android device. Open the Google Play Store app. ...
    • 📱 MobiLearn (iOS) Installation Guide
      This article explains how to install and activate the MobiLearn mobile application on your Apple iPhone using TestFlight. Follow the steps below to complete the installation. 🔹 Step 1: Open Safari Browser Open the Safari browser on your iPhone. 🔹 ...
    • 📱 Breeze FSM – Next Generation (iOS) Installation Guide
      This article explains how to install and activate the Breeze FSM – Next Generation mobile application on your Apple iPhone using TestFlight. Follow the steps below to complete the installation. Watch on Youtube : ...
