🔍 How to Fix GPS Location Not Updating in BreezeFSM?
If your GPS location is not updating correctly in BreezeFSM, follow these steps to troubleshoot:
1️⃣ Check Location Settings
✅ Ensure GPS is turned ON in your phone settings.
✅ Set location mode to "High Accuracy" (Settings → Location → Mode → High Accuracy).
✅ Allow BreezeFSM to access location at all times (Settings → Apps → BreezeFSM → Permissions → Location → Allow All the Time).
2️⃣ Enable Internet & Restart GPS
✅ Turn WiFi & Mobile Data ON for better location accuracy.
✅ Toggle Airplane Mode ON & OFF to refresh network settings.
✅ Restart your device and check if the issue is resolved.
3️⃣ Ensure the App is Not Restricted
✅ Disable Battery Saver Mode (It may block GPS tracking).
✅ Allow Background Location Access in App Settings.
✅ Disable Data Saver Mode (Settings → Network → Data Saver → Off).
4️⃣ Update Google Maps & BreezeFSM
✅ Open Google Play Store → Search for Google Maps → Click Update (if available).
Update BreezeFSM to the latest version from Google Play Store.
5️⃣ Clear Cache & Restart App
✅ Go to Settings → Apps → BreezeFSM → Storage → Clear Cache.
✅ Restart the app and check if GPS works.
6️⃣ Contact Support
If the issue persists, contact the BreezeFSM Support Team:
📧 Email: support@lokaviveka.com
📲 WhatsApp: +91-8981402299
🌐 Help Desk Portal: Click Here
    • 🔧 How to Fix GPS Location Not Updating in BreezeFSM?
      If your GPS location is not updating in BreezeFSM, follow these steps: 1️⃣ Check GPS & Location Services ✅ Ensure Location Services are enabled: ? Settings → Location → Turn ON ? Set Location Mode to High Accuracy ✅ If using an Android device, go ...
    • Unable to Fetch Accurate GPS Address in Breeze FSM
      📌 Feature Name: GPS Accuracy for Shop Visit / Geo-tagging 🖼️ Reference Screenshot: 📝 Description This error appears when the Breeze FSM app is unable to get the correct GPS location from your mobile device. It usually happens due to mobile ...
    • Accurate location not detected through GPS
      This issue likely occurs due to one of the following reasons: ? Troubleshooting Steps to Fix GPS Issues in BreezeFSM: 1️⃣ Restart GPS & Internet ✅ Turn OFF and then ON your GPS (Location Services) and Mobile Data/Wi-Fi ✅ Toggle Airplane Mode ON & ...
    • 📍 Why is my GPS location incorrect in BreezeFSM?
      If your GPS shows the wrong location: 1️⃣ Enable High Accuracy Mode ✅ Settings → Location → Mode → High Accuracy 2️⃣ Check App Permissions ✅ Settings → Apps → BreezeFSM → Permissions → Allow Location Always 3️⃣ Update Google Maps & Play Services ✅ ...
    • Multitab Error When Logging into the BreezeFSM Backend Portal
      📌 Feature Name BreezeFSM Backend Portal – Login Session Management 🖼️ Reference Screenshot 📝 Description This error occurs when a user tries to access the BreezeFSM backend portal multiple times from different browser tabs without logging out ...
