If your GPS location is not updating in BreezeFSM, follow these steps:
✅ Ensure Location Services are enabled:
👉 Settings → Location → Turn ON
👉 Set Location Mode to High Accuracy
✅ If using an Android device, go to:
👉 Settings → Apps → BreezeFSM → Permissions → Allow Location Access
✅ Go to Google Play Store and update:
👉 Google Maps
👉 Google Play Services
✅ Settings → Apps → BreezeFSM → Battery & Background Usage
👉 Select Allow Background Activity
✅ Restart your phone and try again
✅ If the issue persists, uninstall and reinstall BreezeFSM
If the issue continues, contact:
📧 Email: support@lokaviveka.com
📲 WhatsApp: +91-8981402299
🌐 Help Desk Portal: Click Here
